- Gr8lifeExplorer II
smkettner wrote:
Properly equipped the payload is just over 3,000#
GM and RAM have many models with that kind of payload, they call theirs 2500's. Ford insists on winning the name game. I wish one of the others would rebadge a 1000 to show how silly that ploy really is. I have looked at a lot of new pickups in the last twenty years and have never seen one of these "Properly equipped" F-150's on the lot, or I might have purchased one. Instead, I got stuck with the regular models which were just okay. - rbpruExplorer IIOn the door post sticker my F-150 says max cargo of 1411 lbs. this is with the towing package. Other models will vary a bit depending on the trim package.
Yes, with the towing option I have I can pull 9500 lbs.; “provided” I do not exceed the 1411 max cargo. So if I have 1000 lbs. of tongue weight, 50 lbs. of WD hitch, 150 lbs. of truck cap and tools. I could pull a 9500 lb. load, provided I did not weigh over 200 lbs. and I did not want to take the DW, kids or the dog.
It is not the load pulling capacity that stops you, it is the max cargo and how much over it you want to load your truck. - ^^^^ probably best to find the full J2807 testing specs before you decry that nothing applies to the real world.
- majorgatorExplorer
SAE J2807 defines the criteria for setting a weight. C&D offered a good summary. It is acceleration @ WOT based for the weight rating, which IMHO is not how most people drive.
That article is a little bit dated, but still probably relevant to matter at hand. I did find their guidelines to be funny. They want to try and level the playing field and make it more "real world", but those guidelines still don't accomplish that. Its more like those strong-man competitions that used to be real popular. They're measuring limited criteria on a brand new vehicle for short durations of time.
Climbing that grade at no less than 40 MPH for only 11 miles?
The acceleration times being tested??
Unfortunately, I didn't see anything in there about braking. Perhaps the truck can climb that grade just fine, but what's the trans temp once it reaches the top? How does the truck do coming down?
As APT said, these tests don't reflect how real people drive. - APTExplorerSAE J2807 defines the criteria for setting a weight. C&D offered a good summary. It is acceleration @ WOT based for the weight rating, which IMHO is not how most people drive. And RVing limits will be lower due to payload and receiver limits.
Still, a 4WD crew cab with HD towing package is likely to have about 2300 pounds of payload, 100-200 more than 2014 models. - K_CharlesExplorerOur SUV says it will tow 10,000 and if we had gotten the low rear end gears it was supposed to be 13,000. I can break the speed limit most anywhere pulling a little over 8,000 but I wouldn't want to go much higher. I don't know who come up with the numbers but they must be right at the limit.
- fla-gypsyExplorer
beemerphile1 wrote:
What is the payload capacity? A 12,200# trailer will have maybe 1,400# or more tongue weight. Then add all the bicycles, gear, and passengers.
Did you miss the part where properly equipped F-150's will sport 3300lb payload ratings and will be using the new SAE standard? - 2012ColemanExplorer IIMajorGator is correct Clicky
What is the payload capacity? A 12,200# trailer will have maybe 1,400# or more tongue weight. Then add all the bicycles, gear, and passengers.- beemerphile1ExplorerWhat is the payload capacity? A 12,200# trailer will have maybe 1,400# or more tongue weight. Then add all the bicycles, gear, and passengers.
44,056 PostsLatest Activity: Jan 12, 2020
