kohldad
Dec 05, 2020Explorer III
Off road suspension means SOFT, it is designed to articulate and float over the whoopties, go with a truck designed for heavy loads instead.
The soft springs is exactly my first thought. Remember while payload is one number in the calculation, you also need to take into consideration the Center of Gravity. A TC is a lot different than a pallet of blocks because the Center of Gravity is much higher for the camper. So not only are you adding the soft springs, but also several inches between the tires and lift.
While you say SB camper, that doesn't necessary mean a light weight camper. Then you also need to figure out any accessories you add to the truck along with all the junk you through in the camper including water, batteries, propane, food, clothing, bedding, etc which all adds up. Oh and lastly add in the people and pets you are carrying. This all adds up quickly. In my Lance 815 which is designed for a short bed camper with a dry weight of 1,800# everything including one person weighed out at 3,500#!
