Mike_Up
Sep 10, 2013Explorer
pappcam wrote:
The Tacoma is a pretty small TV. Tongue weight and payload is quite limited on them so you'd never reach the "towing" limit on them without being over on those other 2. I'd disregard that 6500lb. towing limit and shop accordingly.
Exactly!
650 lbs tongue weight divide by an average 13% equals 5000 lbs "LOADED".
Subtract 1000 lbs to 1300 lbs for factory options, water, clothes, food, battery, etc and you're at 3700 lbs brochure unoptioned dry weight speced.
There's plenty in this range that will be compatible with your hitch weight.
However, what's your Tread Act sticker payload weight.
My 2008 Sport Trac was the only midsize truck that was truck enough to pull a full size travel trailer. It had a 4.6L V8 with 292 Hp and 300 lbs of torque and with a factory optioned payload of 1218 lbs that "INCLUDED" the hard factory folding tonneau cover that weighed 70 lbs and full length side steps.
We took the cover off to carry stuff so we had a full 1288 lbs of factory optioned payload. The truck had a speced 1400 lbs in the brochure.
We had enough payload for the Jayco Jay Flight 19BH and enough hitch weight capacity (730 lbs rated). The 19BH had a factory optioned dry weight of 3896 lbs. It was on the Tread Act Yellow sticker on the camper.
I'm guessing you have a low payload of 1000 to 1100 which would limit you on who you bring or your tongue weight.
