AH64ID wrote:
otrfun wrote:
AH64ID wrote:
Just because the transmission is made by Aisin does not mean it's the same one and a simple photo comparison says they are not the same as the Ram.
Aisin also makes the transmission in my 4Runner :-)
They are a well known transmission company but so far the only place I have seen calling it the same transmission as the Ram is the forums.... Nothing else backs it up to include photos.
Direct quote from the Truck Trend Nissan Titan Diesel article the OP mentioned: "The exclusive transmission is an Aisin-sourced heavy-duty six-speed automatic, the same unit used for the Ram 3500." I've seen the same thing mentioned in nearly every first-look article about the Nissan Titan Diesel I've read for a number of months now.
The article does say that (missed it), but that article also says it will use the same rear axle as the Ram 2500 Power Wagon.
Look at the rear axle pictured and then read the article. The axle in the photo is the AAM 9.5" Semi-Float 14 bolt used by GM. The axle mentioned in the article is a AAM 10.5" full float axle (not the same as the 10.5" 14 bolt full float). The XD is very obviously using a SF axle and there isn't a Ram 2500 available with a SF axle.
So let's get something other than a truck trend writer/editor as evidence.
Here are some Nissan per-production photos.
http://www.nissanusa.com/trucks/2016-titan/
Then google AS69RC and you will see they are not the same transmission.
Then again why would Nissan want the AS69RC as it is BEYOND overkill and not a cheap option on top of the Cummins 6.7.
Ok, I did as you suggested. I'll let these two pics speak for themselves (Ram 3500 Aisin on left, Nissan Titan Cummins Aisin on right). Looks like a big thumbs up for the Nissan Titan Cummins to me . . .
