enblethen wrote:
hilandfrog:
Tha is not correct information as the OP has a 50 amp rig. He will have a main and some branch breakers. Normally three full size connections to each side of leg. he could then replace full size breakers on the branch circuits with twin breakers.
Thank you, I'd love the education if you could answer my mistakes correctly :)
I stated:
IF 5 circuits is the max for the power center... put in a sub panel ( so IF there were only 5 available whats preferred for adding more ? his pic looks to have 4 twins used with one ?? possible blank?? IF they were all used, and I still have needs, I don't believe I'll be overdrawn, would a sub panel be next in line... asking for a friend :)
What would you do... I'm almost done in my rebuild, added more circuits than needed, so I could shut down systems at will for power on a smallish generator, may not be THE way, but it's the way it is now. Would like 3 more circuits, box is full was planning on another box in the back?
I'll wager the # of circuits changes with amperage.... ( I was thinking a 30 amp would have X number and a 50 amp would add a few to X? is it just that more amps runs larger things not more of them ?)
Thanks for your time
-Repo
