childofthewind
Apr 18, 2014Explorer
ah64id wrote:
Dodge dropped the upper overloads from huge 3500 SRW in 2010. I can only guess, based on my 3500 SRW, that they where not needed with OEM tires. I found on mine that they did not engage until the rear axle was at tire capacity, that doesn't do much good.
The spring pack used on 4th gens in 7% stiffer than the spring pack used on 3rd gen SRW trucks, it's the same main pack that 3rd gen DRW and 4th gen DRW trucks use.
If you are shopping for a new truck the air suspension option should be available soon.
Interesting.
I was excited about the air suspension when I first heard about it, then found out I couldn't get it yet.
Now I have become a bit nervous about it, with the airbags supporting most of the load and located inboard of the leafs, I think sway (body roll) with the high center of gravity of the camper could be a problem.
I would love to find out the air suspension works great, but don't think I will wait for it.
