childofthewind
Apr 21, 2014Explorer
Redsky wrote:
Don't do anything to the suspension until you have a chance to driver the truck with the camper on board. I would check the load capacity for the tires. If it is the usual 3200 lbs. then the rear two will handle 6400 in total less the 3000 lb. weight of the truck leaving 3400 max for the camper which is cutting it very close.
these tires are rated 3640 lbs, and RAWR is 7000 lb, a big increase from where I am at now.
I intend to test it stock 1st, that way I can tell if any modification has helped or hurt.
