BenK
Sep 27, 2018Explorer
Finally, one of my wish ICE's is coming out of the embryonic stage and into proto-typing...
Compression ignition...no spark plugs
Direct Injection into combustion chamber...dry intake manifold
TWO cycle !!!!, to double the power stroke vs an Otto Cycle
https://youtu.be/Ov73-okhkG0
Currently less number of cylinders, but for HD (higher duty cycle) maybe more cylinders
Bottom line is PSI to the piston top and now two piston tops per cylinder
Plus....compression ignition...piston top PSI way higher to begin with...like diesels and this IP ICE can run on almost any fuel...gasoline, alcohol, diesel, etc
44,068 PostsLatest Activity: Jun 10, 2026
