ShinerBock
Jun 29, 2019Explorer
ACZL wrote:
Didn't watch the vid, but amazes me that they cannot get the same specs for trucks to do a sxs comparo. Don't see how a fair comparo can be done otherwise.
If you watched the first minute of the video, you probably would not be amazed about how they could not get the same truck with the same specs because they tell you why.
However, a true specs for specs purely does not exist especially now with 10-speed transmissions in the mix. A trans with more gears(i.e. 10 speed) and a taller rear gear ratio(3.42) is equivalent in terms of torque multiplication as a trans with less gears(6 speed) and a shorter rear gear ratio(4.10) due to the being able to have shorter trans gears with a better spread the more gears you have.
44,068 PostsLatest Activity: Jun 21, 2026
