ShinerBock
Jun 30, 2019Explorer
RCMAN46 wrote:
The gear ratios you used are for the GM 10L80.
I have doubts that the GM 10L1000 will have the same ratios. I base this on the statement in one of the GM videos that you will be able to skip 1st gear when running with no load. This implies a much lower first gear than 4.70 with the 3.42 rear gear.
I have not been able to find published gear ratios for the 10L1000. I suspect they may be close to the Allison TC10.
You are correct. I want back to the GM news letter those numbers came from and it was the gasser 10 speed.
44,068 PostsLatest Activity: Jun 21, 2026
