FishOnOne
Jul 01, 2019Nomad
ksss wrote:FishOnOne wrote:rhagfo wrote:
Weel seeing how the engines are about the same and the biggest difference is the GM had the 10 speed and 3.42 (Tall gears), and the Ram had the Aisin and 4.10's (Low gears), I would say the 10 speed in a GM 3500 DRW will get better mileage, depending on engine RPMs. I now turn about 1,500 with the Aisin and 3.73's at 60 mph, our old 2001 turned 1,800 RPMs at 60 mph with 3.55's, so final OD is taller.
Assuming the fuel mileage readings are accurate on these two trucks I would have thought the duramax would have made better fuel mileage but that wasn't the case. It will be interesting when the drw trucks will be tested at maximum capacity
This will be the real test. I am not sure what the capacity is for the GM 2020 DRW CC 4X4 but both the Ram, Ford and GM should be in the low 30K if they take it to max capacity.
The GM trucks have traditionally outperformed their spec sheet and historically outperformed both of the other trucks up and down the hill. That is not to say it will be the case this time, but if there is a guilty party when it comes to overpromising and under delivering it is from Ford. Who always has the specs but not often is able to deliver it in performance (to the level the specs would suggest). Again these are new designs and what has been the case in the past may not be this time.
Not sure I agree with this... TFL did a DRW race and the Ford beat the Chevy and Ram unloaded when the trucks could reach there upper rpm range. Put a heavy load and they performed within ~2 seconds in which torque played the major role in which all had similar torque ratings.
Dynos:
Factory Rating/Dyno Measurement
Ram:
HP 385/338
TQ 900/828
Ford:
HP 440/387
TQ 925/806
Chevy:
HP 445/337
TQ 910/771
Link
44,068 PostsLatest Activity: Jun 21, 2026
