  • X3 thinking it was a SC. I wanted the Reese SC with purchase, but they messed up. Gave me a dual cam instead.
  • morphrider wrote:
    You are correct, I do have the SC series. My mistake.at a quick glance I thought that was what those were.
    I understand that!!! When I first looked at it, I though "That has been out a while!!!".... Then I looked a little closer and thought something looked weird... Lol Then I noticed the difference.
    I almost went with the SC system. In talking to Reese they convinced me to go with the DC again. I liked the slightly easier set up and adjustment when/if needed, but do like the DC.
    To bad the new model is rated for only 1400lbs tw. Maybe a larger model will be available down the road. It does look like the trailer bracket design seems a little more stout vs the SC.
  • You are correct, I do have the SC series. My mistake.at a quick glance I thought that was what those were.
  • I had the Reese SC system which looks similar in function. I greased the ball and the pivot points where the bars hooked to the hitch. Obviously I did not grease the friction pads. The hitch was wonderful pulling a 6,000 pound BigFoot behind a Titan, never swayed once. It did creak when going slow through campgrounds, not bad and certainly not a deal killer. It looks like they improved the bar to pad covers. The old sheet metal retainers were clumsy.
  • morphrider wrote:
    I have that system. I don't find it to be noisy at all. Zero sway. Pulling a crossroads z218td with a 2500HD gasser. Highly recommend it after 2 years of owning it.
    Are you sure you don't have the SC system from Reese? This new system was not out when we bought our 32 last July. Only the DC and SC systems.
    This has a completely new head design, and slightly different bars in the way they attach to the head.
  • Very interesting!!!!
    One thing from looking at the pics it appears the head tilt does not offer as much fine tuning as the SC or DC trunion system.
  • I have that system. I don't find it to be noisy at all. Zero sway. Pulling a crossroads z218td with a 2500HD gasser. Highly recommend it after 2 years of owning it.
