SilnJohn's avatar
SilnJohn
New tires, up-sizing and load range?
Question on new tires, checking around I can up size my OEM tires from a 275/55 to a 275/60 on the 20" stock rim without rubbing/re-gearing issues. Which moves me from the stock load range of 111 to a load range of 114-117 depending on the tire. I have been happy with the towing performance of the stock tires. But I figure if I have to replace them why not go for more load range and fill the wheel wells better.
I guess the main question I have is will moving from a 111 load range into the 114-117 load range give me a stiffer more stable side wall? and would it be more comparable to a LT C or D range tire?
I only tow about 1200 miles a year in short increments from 50 to 300 miles per trip. So I'm looking for more of a all-season/Terrain tire more so than a towing duty tire. Probably looking at a Michelin LTX or something comparable.
Thanks for your input
  • P series tires are way different from LT series tires. P series tires are all universally rated at 30 or 35 psi (unless it's a designated XL load range, then it's rated at 50 psi). LT tires have load tables associated to them. You typically need more pressure in an LT tire to achieve the same load handling rating as a P series tire. However, LT tires do provide a stiffer sidewall versus the comfort oriented P series tires which tend to have a "Mushier" ride. On my F-150, I actually went from 275/55R20 to 275/65R20. I was 5mph off at 60 mph. The ride was much stiffer as the 275/65R20 tire was an "LT" tire. If the 275/60R20 tire is a "P" series tire, then I wouldn't expect any rougher of a ride, actually I'd expect a softer ride since you'd have a taller side wall and probably suffer just a tiny bit of inaccuracy at the speedo. However, what I found is that in "LT" tire sizes, there are lots of all season tires that have the mountain snowflake symbol on them (meaning no need to chain up when traction tires are required), which is what pushed me to get an LT tire instead.
  • If I only towed 1200 miles in a year, I'd just get the cheapest tire with the best tread life warranty. Not to be a smarty pants but some of our 1-2 week vacations we take have been 1200+ miles. I surely wouldn't spend any more money for a tire that might compromise the ride for a 1-2 week trip. JMO.
