Aginhouse
May 18, 2015Explorer
tenhorsun wrote:
Some of the aluminum looked like new, even though they were 10 - 15 years old. Whereas the fiberglass ones did not age as well.
This is really info thank you guys. I appreciate the responses. I'm questioning the difference between the two. If the siding holds up better why do the bigger trailers typically transition into fiberglass? Is the aluminum heavier? Does the fiberglass insulate better? Is it easier to run the air ducts under he fiberglass?
I can always all to the trailer down the road but can't change the way it's made.
AG
