tcnewbies's avatar
tcnewbies
New to Truck Camping
Hi!
My husband and I recently decided that we wanted to skip our original plan to get a 5th wheel and instead look at truck campers. As we started looking around and exploring weights and options, we ended up a little confused....
We have a 2019 SRW Diesel F350 8ft bed truck that we typically used to haul my 30ft horse trailer. Almost all of the TTs and 5th wheels we looked at we’re totally doable weight wise. Now looking at TCs we’re realizing we might not have enough truck to get us what we want. Enter the place of confusion.... our truck sticker says max weight for cargo and occupants is about 3100 pounds. Which knocks out a ton of TCs. But, when we go and look at everyone’s rigs or read about recommended truck specs from a TC manufacturer, it looks like people are using half ton trucks or 3/4 ton trucks for the TCs within our weight range.
Help! What am I missing here?!?
  • (where's my popcorn?)
    You'll find that with very little searching of the Forum this topic comes up every few days or weeks. Look forward to a hotly debated topic.
    My perspective? While there are some very small and very light campers specifically designed for 1/2T trucks, most campers are designed for at least a 3/4T or 1T truck (or better: 45xx 55xx)
    The most important thing to consider is your tire ratings. In most cases %100 of the camper weight is going to be on the rear axle. Carrying more weight then your combined tire ratings are rated for is unsafe and not recommended.
    - Mark0.
  • You aren't missing anything. Truck manufacturers are required to state a maximum weight (in my case, diesel F350 SRW a gvwr 11,500). My truck weighs 8400 pounds so I have 3100 carrying capacity. I had to look long and hard at campers that I was comfortable with and ended up with a hard side Northstar Igloo 9.5. It weighs 2900 pounds with water and propane. Add another 500 pounds +/- for my "stuff" and I am 300-400 pounds over my GVWR and carrying capacity but under both front and rear axle ratings. I am comfortable at this level. Others are more adventuresome and go heavier. Tires are the weak element and I am also under my tire carrying capacity. A single rear wheel vehicle rules out most slideout campers at least for me. We are very happy with our hardside but others want more room and need (want) slides. The bigger you go, the more you need to think DRW instead of SRW. No matter how much you modify the truck to handle the weight you won't change the stickers. But lots of folks will go to 19.5" wheels, better tires and upgrade the suspension to carry heavier rigs. Shop around, go to Truck Camper Magazine for tips on matching trucks and campers and then go with the amount of "risk" you are comfortable with. And I am not the weight police, I just know what I am comfortable with. Welcome to our world.
  • Quite an interior square foot reduction from considering a 5er to a TC. I suggest renting a TC for a week to make sure.
