Christl's avatar
Christl
New truck and camper questions
I am looking into purchasing a 2015 GMC Sierra SRW 3500HD 4WD Double Cab Long Box 6.0L gas. Question - Will this vehicle easily carry a Lance 1121 w/Slide without other suspension modifications? The Lance is identified as having a dry weight of 3260lbs so I am assuming I could be on the road at 4000lbs loaded with two persons. The truck comes with Michelin 'E' tires rated at 3520lbs/tire at 80lbs pressure and 51mm twin tube Rancho shocks and 33mm front stabilizer bar. The GVWR is 11,000lbs and the front GAWR is 4800lbs and the rear GAWR is 7050lbs. The payload for the above vehicle is listed as 4300lbs. Any guidance is appreciated here. thanks
