Huntindog
Dec 07, 2020Explorer
kohldad wrote:I have done a lot of motor swaps without discharging the AC.... In fact I have never discharged an AC for that reason... Just tie it up out of the way.
Haven't in years but my father and I use to rebuild the old 69 Dodge 318 a number of times, mostly just the heads and exhaust valves.
Is it burning oil? Fuel mileage decreased recently? If not, odds are it is still going strong and doesn't need rebuilding. If so and it was my truck, I would probably tear the engine down for a top to bottom rebuild either myself or a trusted mechanic that routinely rebuilds engines. You may also want to discuss any upgrades for the engine that can increase performance while not increasing the wear and tear on the engine. While you have the engine out causing the AC to be discharged, I would also replace the heater core along with updating the heating unit doors with metal ones to ensure that isn't the next thing to go wrong.
