KansasKen
May 01, 2012Explorer
Have you tried to get a air chuck or truck style gauge on the outside wheel valve stems yet to add air or measure pressure? The placement and angle of the stem on my same wheels is impossible to get at, unless you use a short gauge and hold it between the tires then don't bump the gauge getting it out to read. Adding air is similarly a problem. I am going to try a set of pressure monitors from Crossfire (similar to Cats Eye)and see if I can figure out how to mount the center unit. I bought my 19.5 set last year for a F350 4X4 Crew Dually to carry a Host Everest TC. Mine do not stick out past the wells. I run 100lbs and the truck will track with road grooves, more so when unloaded. (Firestone airbags and Rancho 9000s)
