msiminoff
May 16, 2012Explorer II
dmaxpuller wrote:
They wanted to use Equal for balance. I am going to have them use Dynabeads.
Also, did you get the tires sipped. I am going to have mine done. Not real deep, but enough to open the lugs up for better traction and a little softer ride.
Dmax, I gotta ask; Why & why?
I think Dynabeads are terrific for tires that need them... but it sounds like you haven't even mounted yours up yet. I'd suggest starting with match-mounting & road-force balancing. This would identify an out of round or out of balance defect in a wheel or tire at which point you could have it replaced before you ever put 'em on your truck.
If you can't get a satisfactory ride after spin balancing, then you can always add the Dynabeads later.
Siping is also cool, but its primary purpose is for improved traction in winter conditions (ie. ice)... and you live in California where we are heading into summer. Again, I'd suggest starting with the tires not-siped (new XDS2's are manufactured with sipes in them to begin with) and then consider siping if you are dissatisfied with the dry traction or do it closer to winter (IF you're going put down significant miles in winter conditions).
Just my $0.02, take it for what it's worth.
Cheers
-Mark
