Peg_Leg
Jul 11, 2014Explorer
Most advertising tow info for trucks is based on the basic stripped down model. You need to get specific on the truck as everything added reduces load capacity. 4X4's typically have a lower rating than a 2 WD model, extra cabs less than a standard cab. Above all check the rear axle rating, tires are usually the weak link. Some models have passenger rated tires that severely limit the rear axle load rating. Each tire will have the max PSI and weight that the tire can safely handle. My old TT had GVWR of 8,000 lbs and a tongue weight of 1,200 lbs loaded dry.
44,056 PostsLatest Activity: Nov 19, 2013
