Gdetrailer
Nov 11, 2017Explorer III
revcrab wrote:
Hmmm. Let me check the Help forums. Again.
I believe the forum rules require a certain minimum amount of posts before you can attach a link..
For photos, you must use an external photo hosting site that allows hot linking. That site then will give you a URL address that can be used on this site to show the photo.
For detailed info on posting photos here is a link to the forums technical support section..
Photo Posting Support
There was a Moderator (1492 I believe) who setup a special storage and linking account which worked great, sadly I just tried that and it is now no longer working :(
Once you have a shareable URL link you then use the Advanced Post Form which gives you advanced editing and you will see a button at the top of the text form that looks like a mountain with a sun.. That is the photo attachment button..
If you have a Google Email address, you should have 15GB of free online storage, you can make a folder in that online storage and set the folder and or files as shareable..
Once set to shareable you can generate a URL link to those files which can be used on this forum using the Advanced Posting Form!
