DutchmenSport
Mar 25, 2015Explorer
More than likely, wherever you have your truck registered is where you will need to register and title the camper until you get relocated. That might be difficult, purchasing the camper then having to return to Hawaii to register and get tags - title - insurance, and then return back to the lower 48.
You did not indicate what your intentions are after you reach your final destination. Will you be wanting to keep the camper and continue using it, or is it your plan to sell it, or liquidate it once you finally "arrive?"
If your plan is is to "liquidate", you might consider rentals. If you can find a company that will rent a trailer one-way.
The other option you may consider is a small truck camper. Depending upon your state of residence, you may not have to have a separate license plate for it. It's consider "cargo." Just an idea!
Good luck in your endeavors and I enjoy your excitement! Don't get discouraged. You can make it work!
