OutdoorPhotogra
Mar 26, 2015Explorer
Look at the sticker in the door and see what the axle code is. That combined with your will tell you what your tow rating is. Also, if you have the tow package, it should have a class IV hitch (Pretty sure it's class IV, not III). If you look under the hitch, or better yet if you have a smart phone, you can reverse the camera and use it to read or take a picture of the label. Mine says 500 lb tongue weight/5,000 lb tow limit or 990 tongue limit and 9,900 tow with weight distribution hitch.
If you google the ford truck forum, there is a guide for the codes on the door. Also, there is a window sticker locator based on VIN that will give you original specs on truck per window sticker.
