hawkeye-08
Dec 15, 2014Explorer III
Just posted this on another thread, seems to apply here too. Since you already have your tow vehicle, use the door sticker to figure out what you can get.
This is all being driven by the OEMs claiming every increasing tow capacity. The truth is, the payload is the critical factor when pulling travel trailers. It would be rare that you are at the towing capacity with a travel trailer and not over on the payload (talking normal 150/250/350 trucks)... especially with the options folks are getting on trucks.. another story if we are talking boats. Tongue weight on travel trailers tend to need more than a boat or car trailer.
Payload is not a hard rule (one that 5 lbs over is going to break everything) but is a guideline. Give yourself some margin and you will be more comfortable typically rather than at the spec limit and wondering all the time.
The way I look at it is, your budget is going to limit most folks. You can cut most of the BS out by simply using the facts.
Take pictures of the door sticker on trucks you are interested in. Make notes that go with the pictures so you can remember which is which. Do the same with trailers, most trailers now have a sticker that shows weights as shipped from factory. Add the dealer installed options and you get a base weight to work with. You will need to do some math to see what would the expected tongue weight would be based on the trailer weight. Remember to count batteries and propane. Invest in a Sherline tongue weight scale and take it with you when looking at trailers. I weighted many trailer tongues when we were shopping for our first trailer. It kept us from buying something that we obviously would not be able to tow.
When it is said and done, you will find a tow vehicle that meets your needs and has xxx available payload, which tells you what you can reasonable tow. Based on the payload available (give yourself some margin), you can then select a trailer. If you don't like the choices in trailers that a given payload will handle, then change tow vehicles.
BTW, we did this and still ended up with a less than desirable combo because we had an SUV that was not ideal for towing (P rated tires, soft suspension, limited hitch capacity, hitch that flexed too much, etc). We ended up trading for 2500HD pickup after 3 years of less than desirable towing experiences. After trading for the 2500, towing was a pleasure... of course more TV meant we could go bigger on trailer, but with the experience of the first trailer and TV, we found the trailer we wanted that tows very nice behind the 2500 (with new hitch and WDH). If you are guessing at tongue weight, use 13% of the trailer GVWR (max trailer should weigh). This will give you a reasonable estimate (note that toyhaulers are generally higher on tongue weight unless you load up the toys in the back).
Ask all the questions you want on the forums, it is much cheaper than buying something that does not work.
44,066 PostsLatest Activity: Oct 04, 2013
