KD4UPL
Mar 04, 2018Explorer II
Nothing in the numbers you gave tells the tow capacity. I doubt you're gaining much ability, if any. An equivalent 250 is and extra $20,000? Either what you're buying is super cheap or the 250 is way overpriced. Or, were you looking at a diesel 250? They would be significantly more but the diesel engine is unnecessary.
If your trailer is 5,600 dry it will likely be 6,500 or higher loaded up. That will likely put over 1,0000 pounds of tongue weight on the truck. Add in the weight distributing hitch (around 75 to 100 pounds), the family, firewood, bikes, generator, etc. and you will likely be pushing the limits of the truck's payload.
If you have a very small family and travel light you will likely be well withing the specs of the old or new truck.
44,056 PostsLatest Activity: May 04, 2014
