APT
Mar 04, 2018Explorer
Going from a 2006 vintage half ton to a 2013 vintage will be significantly better with respect to power and acceleration. Payload and handling will be very similar, so if you are comfortable now with handling you should still be with the proposed 2013. The 6-spd trans will make much better use of the V8 engine's power. 3.31 axle with 6-spd trans is much better than your current truck even if it had 4.56 axle ratio.
44,056 PostsLatest Activity: Jan 12, 2020
