tonymull
Oct 09, 2014Explorer
Much better! Couple of observations. @1200lbs dry weight you will end up over 2000 lbs wet...so you will be pretty far over your payload capacity. That will be, and no doubt has been, tough on the truck's suspension. You can see some squat in the picture. This rig will not be fun to drive. Plan on needing some suspension upgrades. Second, notice that the camper is longer than the truck's bed. That means that the center of gravity is off and that puts more weight on the rear. Makes the drive even less fun. Not sure what kind of selection you have to shop from, but I'd pass on this one. I started out with a very similar rig, except the truck was almost new. Worked OK on freeway travel but I would never have taken in on rough roads. Now if you could score that camper with a bigger truck... However is half of the $12K price is for the camper it is overpriced by $2-3K.
44,056 PostsLatest Activity: May 04, 2014
