RedRocket204
Oct 30, 2015Explorer
PureMI wrote:
w/washer solvent is quite toxic as well, whereas RV antifreeze will not kill you. It's cheap insurance.
OP's question was regarding only the P-traps for use with winter windshield fluid.
But you are right, it should be mentioned to NEVER use windshield fluid in the water lines as it is considered a poison: www.poison.org - Windshield Washer Fluid: A Winter Hazard
www.poison.org wrote:
Windshield washer solution contains a chemical called methanol. If swallowed, methanol can cause kidney failure, blindness, and death.
