SoundGuy
May 30, 2018Explorer
Unfortunately you haven't indicated just which Reese system this might be, whether it requires the use of a separate friction sway bar or whether it's a WD system with integrated sway control, as is the case with the Blue Ox Sway Pro. Hard to go wrong with the Sway Pro if you can afford it. Regardless, keep in mind that it's difficult at best to properly set up any weight distribution system on an empty trailer and you may well have to make your own adjustments to it once you've figured out how you're going to best load your new trailer for camping.
44,026 PostsLatest Activity: Feb 22, 2025
