DToutain's avatar
DToutain
Newbie Question on Leveling
Want to be able to use Rockwood Mini Lite 2304 in backyard when not travelling as a 'guest house'. Problem: ground not level approx 3" rise. Have purchased leveling lynx. Black tank output is low to the ground. Unable to maneuver to this height comfortably just using the lynx levelers on one side.
Thought I might use a Bottle Jack to raise tires and slip in the lynx levelers. Then, lower and remove the Bottle Jack, letting the tires come to rest on the lynx levelers.
First, is this feasible? Second, what is recommendation for Bottle Jack? Third, where should jack be located to raise high enough to insert levelers?
Any suggestions would be appreciated. Thanks!
  • Get two 2x8's 3 or 4 feet long. Stack them on top of each other, staggered slightly, like a ramp. Drive the low side tire up on them, now its level. Block the wheels, you're good to go.
