L_R_G
Jul 08, 2013Explorer
lanerd wrote:
I think you would do a better (faster) charge if you brought along a regular battery charger (up to 50 amps) and plugged that into the Honda (might need a 2000w Honda) and then used the charger cables to your trailer battery.
Just a thought.
Ron
Depends on the charger in OP's unit. My 26' came with a 55A charger/converter so plugging in a 50A external charger wouldn't be a benefit for some.
Also keep in mind if you're so inclined you can also connect jumper cables from your TV to your TT batteries and charge that way as well. One plus is you avoid the inefficiencies of converting from AC to DC power and the alternator on your TV is likely to produce more output than the charger in your TT. Getting max output would require reving up the engine. In my diesel Superduty I use the high idle to get the best alternator output.
44,066 PostsLatest Activity: Apr 16, 2026
