You didn't mention if that Liberty is factory or has the upgrades (tranny cooler, etc) on it.
I had a Suburban that was rated for 5500 lbs and I towed a 4500 lb (dry) 25 ft TT, with accessories, on flat ground, with myself and my wife. Total weight would easily be around 5200-5400 lbs. After about 2 trips in the summer (150 miles each), tranny died. I did not have a tranny cooler on it. This was back a few years in one of the hottest summers MN had.
On my Dodge Ram 3/4 ton, we put in the tranny cooler, and it had the towing and snow plow packages added. I towed a 6800 lb (dry) 29 foot trailer with that and again, we got fairly close to max at around 8200 lbs. The difference was that a WD hitch on that one helped. Any hills were less than exciting though.
Also the Liberty is kind of short wheelbase so it depends on how comfortable you are when it's all loaded up. A slight breeze could make you ... less comfortable.
