MNGeeks61 wrote:
The weight of the hitch itself has to be added too.
Maybe 100 lbs for the hitch, 600 lbs for necessities, 300 pounds for you and the wife and boom, you are right at max towing capacity. As mentioned, a short wheelbase also is going to impact your comfort zone...
Some manufacturers call the "dry" weight anything without accessories like a roof A/C, so the max comes even closer. I wouldn't be towing that with a Liberty.
The Yellow sticker on the TT is the weight of the TT you see sitting on the lot. If it has a AC, it is included in the sticker weight, as is propane tanks, awning, stove, and well what ever is on it as you see it.
