Thanks,
The specs say that the tongue weight is 600 lbs and I'd guess that seems about right. The TT weight is 5,700 dry and we don't have much inside and I travel with the tanks nearly empty. I am running 80 psi in the trucks back tires and 60 in the front as per the label on the door frame. 50 psi on the TT tires.
With the Reese hitch the TT seems about level and the truck does not sag much when the TT goes on the ball. Honesty, I am not sure what a WDH hitch does nor how sway bars work either. The sway I get is usually at speeds above 65 mph and is not too bad and it settles down quickly. Still, it can be somewhat unnerving.
Over all, I am happy with the truck and TT. I want to get a camper shell on the truck bed so that I can put stuff in it and lock it up when we go sightseeing.
Handye9, I looked at your mods and they look really good. I did ten years in the good old USN. 72 to 82. MM1 on some sea going, bad to the bone combatant ships.
Thanks again and I'm sure I'll have more questions as we get started on this new adventure. We plan on being on the road about three months.
