BamaTrav's avatar
BamaTrav
Newbie Truck and Trailer Shopping
As the subject line indicates, wy wife and I have decided to finally pull the trigger on a trailer. We are still in the process of researching trailers, but first need to address the issue of a tow vehicle, as we feel our trailer needs exceed the capabilities of my wife's 2011 Sequoia. As a result, I am truck shopping. Here is the rundown:
My wife and I are considering purchasing a 2015 F150 Super Crew short bed with 3.5 Eco and 3.55 Gears. Ford's trailer guide indicates 10,700 towing, a payload of 2,060 and a GVWR 700o. My crew of five weighs in below the 650 mark and will likely add less than 100 lbs in the coming years. I am thinking even with a couple hundred pounds of bikes and beach gear in the bed there is still plenty of cushion for tongue weight. I want to err on the safe side. That being the case I would appreciate thoughts on max SAFE trailer and tongue weights. Is 7000 lbs or so and the associated tongue weight reasonable? I am second guessing myself after reading about inflated tow ratings and the often overlooked payload issue with 1/2 tons. Thank you for any and all thoughts.
