Buzzcut1
Aug 10, 2015Nomad II
weigh the truck with a full tank of fuel at a cat scale and get a per axle weight. take your tires max load x2 and subtract the scaled rear axle weight. that is what you can carry with your current set up in the bed, regardless of what the MFG sticker in the door frame says. Go from there. Remember the true camper weight will be between 500 and 1000 pounds heavier than the mfg sticker once you add in gear food water propane and batteries.
