ticki2
Aug 11, 2015Explorer
TN Sportsman wrote:
2003 Chevy 1500 HD 4x4 Crew Cab, 6.5' bed, 6.0, 4L80 transmission, 3.73 gears,4 wheel disc brakes, E-rated tires, Quadrasteer, 8600 lb. GVWR, 4410 lb. Front axle, and 6000 lb. rear axle. From my understanding, the "1500" badge is misleading to most, as it actually specs out nearly the same as a 2500 non-HD.
You are correct , a 1500HD is almost identical to a 2500 non-HD . Your crew cab will seat 6 , 6 x 150 = 900# , if there is only 2 you can add 600# to the TC capacity .
