Ace_
Aug 13, 2015Explorer
Some of the mfg, Four Wheel Camper, lists the base weight and then lists the weight of each option. Of course you could buy a "shell" model and the weight would be real close to the listed weight, but you can also just take the base weight and add the weight of each option. Much closer than guessing. Too bad mfg don't all do this, or have to have each unit weighed. My thought is to take the GVW of the camper and use that number, knowing you're not likely to exceed that.
