msjdbman wrote:
joegray wrote:
If you take it to a dealership or someone with a code/scanner computer they should be able to force the clutch fan to engage through the computer. That way you would know rather than just throwing parts at it. I would also put a new rad and thermostat in it that way you know it's clean with no restriction. JMHO
The fan clutches on these are an internal thermostatically controlled unit. They can not be forced to come on by anything other than heat. According to my dealer, they have replaced the clutch on many 08`s and 09`s. Mine included just 2 years ago now. My truck was doing exactly the same that the op described. As soon as the fan clutch was replaced, the issue was resolved.
This is 100% correct. If the fan doesn't engage the first start of day for a few minutes -it is probably not working correctly. Without it working correctly -the fan never actually fully engages to create the pulling effect needed. AC system not functioning correctly could also induce overheating....
