RoyB wrote:
Too bad your 2000 F250 does not have the two trailer sockets sitting side-by-side for the 7-way and 4 way connections. My 2004 Truck and my 2010 Truck are equipped this way... I always hated to have to splice into something already wired up and I usually create problems hehe...
These connections only power up your truck camper or pull trailer safety lights and brake controller if equipped. Some may have a low current 12VDC coming from the truck start battery at these connectors as well. The 12VDC items in the truck camper are powered by its installed 12VDC BATTERY or Inverter for 120VAC items. Shore power connections provides 120VAC to operate the 120VAC items in the truck camper as well as the converter/charger to operate the 12VDC items in the camper as well as charge the camper battery.
This is a GOOGLE photo of the 2000 F350 trailer connectors having the dual connector setup.
This is kinda neat where the 7-way side would feed your Truck Camper safety lights and then your small tow trailer would plug into the other trailer 4-way or 5-way connector.
Don't know how small your tow trailer is but if it has electric brakes mounted on the hubs it will require by DOT a BRAKE CONTROLLER hookup.
Might want to check with your local safety inspection station to get a reading on what will be needed...
ETRAILER is one of the best places to get things like this on-line. They have everything trailer....
Your Truck camper may have some overhang and might require a short extension 4-way/5-way cable for the second trailer connection.
This is GOOGLE PHOTO of a ETRAILER Dual trailer hook-up combo connector my truck has.
just my thoughts here...
Roy Ken
The only problem with the pictured ones that are right next to one another with the flip open covers is if you need to use both of them at the same time you are out of luck. If you lift the flap for either one it makes the other one not useable as you can't open both covers at the same time. I know I had those types on both my 2011 Ford and my 2013 Ram. Really sucked till I added my 7 pin in the bed of the truck for the camper. I needed to pull my boat at the same time as hauling my camper.
