Kayteg1 wrote:
Reddog1 wrote:
I recently purchased a 2004 Ram. I will be installing the following $250 filter system, not simply to add filters, but to have a 4 micron filter instead of the OEM 7 micron filter.
Cummins Dual Filter Kit I plan on using the Donaldson P551313 Filter and Baldwin BF1212 Water-Separator.
Wayne
I had Racon (?) fuel system on my VW years ago - install by PO. '
Had to disconnect it as maze of orings develop never ending leaks.
When leak on vacuum fuel system leave no stains on the floor, they lower performance and kill the engine at some point.
Racor is the brand.
To Reddog, take a look at the Glacier Diesel single filter kits before you get the double.
I installed one after killing a couple injectors by 120kmi.
The glacier kit mounts nicely under the hood, after the factory filter/ water separator.
So IMO it achieves the same thing and it's not under the truck where everything gets dirty and beat up.
