I am convinced I experienced the "death wobble". After some research, I discovered Ford has acknowledged the problem in a TSB (they call it steering oscillation) and some part kit should fix the issue. I'm making a call to the dealer to get it looked at.
TSB # 18-2268
Model: Ford
2017-2019 F-Super Duty
Issue: Some 2017-2019 F-250/F-350 4WD vehicles built on or before 31-Jul-2018 may exhibit a sustained steering wheel oscillation after driving over rough pavement or an expansion joint above 45 mph (72 Km/h).
Action: Follow the Service Procedure steps to correct the condition.
Parts
Part Number Description Quantity
HC3Z-3E651-D
Steering Linkage Damper 1
5C3Z-3B440-EEE
1º Adjuster Assembly 2
5C3Z-3B440-DDD
3/4º Adjuster Assembly 2
5C3Z-3B440-CCC
1/2º Adjuster Assembly 2
5C3Z-3B440-BBB
1/4º Adjuster Assembly 2
F2TZ-3A049-A
Castle Nut 2
W525288-S437
Cotter Pin 2
