Groover
Oct 05, 2018Explorer II
hone eagle wrote:
If it is a push rod engine ,the reason most likely is packaging ,it will be used in motorhomes not just pick ups and it makes the doghouse smaller
That plus I believe that this is meant to be a relatively low RPM truck engine. The over head cams seem to help more at higher RPMs. I can't find it now but I saw a video a few weeks ago showing almost a ramp in the head design to add a lot swirl to the incoming air to get better fuel mixture for cleaner and more efficient burning. This could not be done with a four valve engine, hence the two valve design.
44,066 PostsLatest Activity: Apr 16, 2026
