- RobertRyanExplorer
RoyJ wrote:
smkettner wrote:
Need 3500 payload to really fit the niche. Otherwise F150 8200 gvwr covers it better IMHO.
I think Nissan undersized the first Titan rear axle also.
3500!? That's beyond the abilities of most true 3/4 ton crew cab diesels. Ram couldn't attain those numbers till they went to coil rears, 11.5 axle, and 50ksi frame...
This truck is a direct competitor to the 8200 F150 that you mentioned. Neither of which comes near 3500 lbs payload in the crew cab configuration.
In fact, I bet the crew cab, 6.5' bed F150 is pretty much bang-on with this Titan's payload, and that's before factoring in the heavier diesel.
As I have posted elsewhere , the only standard Pickups that come close are what you get outside the U.S., or the 1 tonners as they are called here. I think the recod now is 3200lb - transamz9Explorer
RoyJ wrote:
rjstractor wrote:
jus2shy wrote:
Same aisin as in the ram. As69rc, overkill really.
So this thing has a engine and transmission both designed for medium duty commercial truck usage and a 13 inch rear axle. We know that Nissan has suspension and running gear in their parts bin capable of supporting a 10Kish GVWR truck in their NV3500 van. Maybe this thing is really a 2500 series-spec truck, but they are not marketing it as such because it has considerably less hp and torque than the big 3 diesels.
The 13" ring gear is likely a mis-print. A dually Ram 3500 only runs 11.75".
13" is well into 450/4500 territory.
I seen an ad on FB that said "available goose neck hitch" This was on FB so IDK but it was a Nissan page. Maybe someone can look around on there. I can't do it from this computer. - Turtle_n_PeepsExplorer
Something's weird here. There is no reason to use a 13" ring gear in this truck. It would just waste fuel and HP and serve no purpose. Nowday's nobody wants to waste fuel..........not even a drop. - fx2tomExplorer
brulaz wrote:
fx2tom wrote:
Nissan had them out in Southern CA this weekend so me and the little guy went and looked at them and I will say that, in person, I was drooling. The interior is very very nice and the outside actually looks pretty good. I told DW that I'd be seriously considering a new truck when this things hits it's second or third model year and all of the kinks are worked out.
Did you get a good look inside?
Was there a Exhaust Brake knob or switch?
Haven't seen anything in the press about Nissan using the Cummins 5L exhaust brake so was wondering ...
I didn't get a lot of time inside but there was a switch next to the brake controller but the guy from Nissan had like 10 people waiting to talk to him so I didn't wait to ask. - brulazExplorer
Haven't seen anything in the press about Nissan using the Cummins 5L exhaust brake so was wondering ... - fx2tomExplorerNissan had them out in Southern CA this weekend so me and the little guy went and looked at them and I will say that, in person, I was drooling. The interior is very very nice and the outside actually looks pretty good. I told DW that I'd be seriously considering a new truck when this things hits it's second or third model year and all of the kinks are worked out.
- spud1957Explorer
The F150 HD Payload package for 2015 is now 7850 GVWR. - RoyJExplorer
13" is well into 450/4500 territory. - RoyJExplorer
In fact, I bet the crew cab, 6.5' bed F150 is pretty much bang-on with this Titan's payload, and that's before factoring in the heavier diesel. - wuhungsixExplorerI had a first gen Titan (first truck ever). I was ignorant and I loved that truck to death. Still miss it. Even through its issues mostly squeaky cheap interior and constantly failing rear axle seals.
I'm new proud fan of Cummins engines as I now have a 1-ton 6.7 Cummins SRW. I was secretly hoping for a great looking 2nd gen Titan to carry the 5L Cummins. But man that thing is hideous! I always liked the Tundra aesthetics and hope they can put a better face on this powertrain.
44,056 PostsLatest Activity: Jan 19, 2025
