- kw_00ExplorerYep all gm 2500HD trucks since 2000- up have at least 9200GVWR, my last 1500HD had 8600. So where the 8500 came in I'm not sure cause I have never seen that....
ShinerBock wrote:
2010 Chevy 2500HD 6.0 GVWR 8,500 lbs <--- this one is technically a "1/2 ton" since it is below 8,501
My 2005 2500HD had a 9200 GVWR as have all other 2001+ 2500HDs that I've seen. The 1500HD had an 8600 GVWR.- blt2skiModerator
ShinerBock wrote:
Bedlam wrote:
I would prefer to call trucks by class rather than name to avoid confusion. I have owed two Class 1's, a Class 2b and now a Class 5. Payload is definitely an inaccurate way of describing trucks with the same name but configured vastly differently.
I am with you there.
x millions - ShinerBockExplorer
I am with you there. - BedlamModeratorI would prefer to call trucks by class rather than name to avoid confusion. I have owed two Class 1's, a Class 2b and now a Class 5. Payload is definitely an inaccurate way of describing trucks with the same name but configured vastly differently.
blt2ski wrote:
ShinerBock wrote:
I take back what I said earlier, it was less than ten years ago that 250/2500 trucks had the same GVWR of this Titan XD.
2010 Ford F250 5.4L GVWR 8,800 lbs
2013 Ram 2500 5.7L GVWR 8,800 lbs
Depends upon YOUR definition of a half ton, or what "I" would call a class 1 truck. Since over 6001 lbs, it is a class 2 or 3/4 ton! Along with a LOT of 15/half ton badged trucks frankly.
I believe the split between an HD and LD class 2 is 8400, not 8500, but I could be wrong.
Marty
The split is at 8,500 and 8,501.
DieselHub - Truck Classifications
Wikipedia - Truck Classifications - blt2skiModerator
Marty - ShinerBockExplorerI take back what I said earlier, it was less than ten years ago that 250/2500 trucks had the same GVWR of this Titan XD.
2010 Chevy 2500HD 6.0 GVWR 8,500 lbs <--- this one is technically a "1/2 ton" since it is below 8,501 - blt2skiModeratorTechniquely speaking from the federal truck stds,
up to 6000 gvwr is a class 1
6001-8400 is a ld class 2
8401-10000 is a HD class 2
10001-13.5K? is a class 3
13.5-16.5 class 4
16501-19500 class 5
19501-26K is class 6
not going into 7 and 8.......needless to say, yes, a 35 badged rig with a less than 10K gvwr would be considerd a class 2, or 3/4 ton style truck. Even my 89 GM duallie, with a 10K rating per GM back then, was a class 2, as its gvwr was not over 10001!
Marty - ShinerBockExplorerWhat would you call all of the 2004 and below 350/3500 SRW trucks? Most would say they are a "1 ton", but based on their GVWRs of less than 10,000 lbs, they were technically 3/4 tons going by class.
Hell, most 250/2500 just ten or so years ago were rated at the same GVWR of 8,800 lbs as this Titan XD. So are those trucks called "LD 3/4 ton" trucks too based on what is said here?
