Wharfcat
Jan 23, 2019Explorer
Rustofer wrote:Wharfcat wrote:
I've got a 2018 Ford F-350. So I decided to cut the Lance propriety plug off the camper and wire up a bargeman. I had a cord I bought from Torqelift many years ago, just in case I bought a new camper. The Torqelift cord was wired incorrectly, which is another story. All the lights work correctly but I have no power to the 12 volt charge line, Running or stopped. Looked at the fuse box and in the #27 slot there is a 30A fuse so I'm thinking I'll go talk to the Ford dealer tomorrow unless someone already knows the answer.
My 2017 F-350 requires the camper to be plugged in, so it senses the load, then with the truck running press the brake pedal for >3 seconds to activate the power circuit. If I remote-start the truck, I don't get power back there until the key is in and on.
Thanks I'll check that. Right now the camper is unloaded and bad weather rolled in.
The volt reading on the camper should be something above 12 volts, 13 or 14 when being charged?
44,071 PostsLatest Activity: Aug 16, 2026
