hellfirehydraExplorerAug 21, 2017No D.C. Power at thermostat.So I'm not getting D.C. Power at my thermostat. I can take a good +12v wire and start the fan or compressor. Circuit breaker is working and I ran the "good" +12v from there to check. Where does...Show More
Chris_BryantExplorer IIAug 21, 2017What air do you have, what is hooked to RH and W on the thermostat ?
Related ContentNewbie power question12 Volt Power IssueDriving through D.C.SOLVED: No power getting to the thermostatWhy two thermostats?
