hellfirehydra
Aug 22, 2017Explorer
Sure. The old thermostat and new thermostat have the wires going to the same components minus not having the gray low speed fan wire.
Blue is the hooked up as a common ground.
Green is hooked up to the high speed fan. 0V DC
Yellow to the compressor. 0V DC
White to the furnace. 0V DC
Red to R & RH. +12V DC
Again, the AC functions normally. The heat function causes the issue with the thermostat heating up.
The furnace functions normally with the white wire attached to the red wire that is hooked up to R & RH.
44,056 PostsLatest Activity: Jan 22, 2026
