hellfirehydra
Aug 22, 2017Explorer
hellfirehydra wrote:
Sure. The old thermostat and new thermostat have the wires going to the same components minus not having the gray low speed fan wire.
Blue is the hooked up as a common ground.
Green is hooked up to the high speed fan. 0V DC
Yellow to the compressor. 0V DC
White to the furnace. 0V DC
Red to R & RH. +12V DC
Again, the AC functions normally. The heat function causes the issue with the thermostat heating up.
The furnace functions normally with the white wire attached to the red wire that is hooked up to R & RH.
Ok just figured it out. Blue was not supposed to be connected in addition to white unless I had a heat pump. Blue is a -12v wire and in new thermostat blue is for a heat pump. Disconnected blue and now the AC and furnace both operate properly. It was even a warning in the instructions...oops.
Who knew I should have read the book full of words and pictures more carefully. I was mixing and matching instruction manuals in my head between old thermostat and new.
So I ended up with yellow, green, white, and red hooked up. I capped off blue (-12v) and gray(low speed fan).
Thank you all for the help.
44,056 PostsLatest Activity: Jan 12, 2020
