Lantley
Jan 10, 2016Nomad
Outlets in the slide are one of those often overlooked features.
The easiest way to remedy the situation is to install outlets on the permanent wall at either or both ends of the slides. By installing outlets in permanent walls, you avoid installing wiring that has to move with the slide.
